Design articles
Articles
Archicad Design Checker
Design Checker is a new Archicad functionality that offers easy-to-use model checking capabilities for users to capture errors as they design, right inside Archicad. It utilizes a cloud service called Solibri Inside developed by Nemetschek sister com...
ArchicadDesignChecker.png SolibriInsideChecks.png PropertiesCheckResults.png LastCheck.png
Create a Copy When Stretching Circles
User interactions should behave consistently and with expected results The behavior of the radial stretch command for curved elements was inconsistent, leaving a gap in the user’s workflow when working with circles and ellipses because it was not pos...
Importing Point Clouds and Modelling the Terrain
A quick way of inserting the representation of the terrain to our model is using the point cloud import feature of Archicad. Point clouds are more and more popular since they can give the most detailed surveying results, however at the same time need...
openpitmine.jpg screen-shot-2016-02-05-at-11-14-19.png screen-shot-2016-02-05-at-11-40-21.png screen-shot-2016-02-05-at-11-45-53.png
Ramp Parapet with Morph Tool
Place a Ramp Object I felt it is good to share some software specific tips and tricks in between my posts focusing on interoperability. In this post I am sharing a tip on how to create guard walls (parapets) along the edge of a curved ramp using Morp...
Frameless Corner Windows
One kind of a recurring issue is how to create the frameless corner windows, using just a mitered glass connection as below: Switching to the Custom Corner… tab page of the Window settings however doesn’t allow us to choose Glass, but Frame or Corner...
Joining Wall Segments
Adding new nodes to a Wall when editing it via the Pet palette eventually creates segments which cannot be joined again using an inverse command or such. Though it is not something you could not solve by deleting one of the segments and edit the rema...
Grasshopper-Archicad Live Connection for MAC Test Run
The MAC version of the Grasshopper-Archicad Live Connection has been released recently, so it was high time doing a test run on this platform as well. The following is not focusing on the performance and the features, the pure intention is to give so...
