Design articles
Articles
Grasshopper-Archicad Live Connection for MAC Test Run
The MAC version of the Grasshopper-Archicad Live Connection has been released recently, so it was high time doing a test run on this platform as well. The following is not focusing on the performance and the features, the pure intention is to give so...
Converting Sketch Models into BIM Models
There seems to be a clash between design sketch models (typically coming from SketchUp or Rhino, but even if they are created with Archicad) and models created for proper BIM use when we need to convert one to the other since they are built with comp...
Grasshopper — ARCHICAD Live Connection
The Grasshopper - ARCHICAD Live Connection is a part of the Rhino – Grasshopper – ARCHICAD Toolset. Generate and manipulate BIM elements in ARCHICAD directly from Grasshopper This tool enables Rhino/Grasshopper and ARCHICAD to communicate directly in...
wp-content_uploads_2020_05_icon-grasshopper-archicad-live-connection.png wp-content_uploads_2020_05_banner-rhino-grasshopper-2019.png
Algorithmic Design
What is algorithmic design? If you are not yet familiar with this term, watch this video below: Rhino – Grasshopper – ARCHICAD Toolset Rhino – Grasshopper – ARCHICAD Toolset connects the best design tools for the different design stages on both Mac a...
wp-content_uploads_2021_08_banner-rhino-grasshopper-2017-v2.0.png wp-content_uploads_2021_08_icon-grasshopper-archicad-live-connection-1.png wp-content_uploads_2021_08_icon-rhinoceros-import-export-add-ons.png wp-content_uploads_2021_08_icon-rhino-archicad-gdl-converter.png
Grasshopper Connection Object Guide - Sweep Object
With the Grasshopper - ARCHICAD Live Connection, you can enhance your BIM model with complex shapes that can not be defined easily with the default ARCHICAD tools. In order to be able to properly represent and document these shapes, while keeping the...
wp-content_uploads_2019_08_simple-curve-cover-photo-1024x477.png wp-content_uploads_2019_08_object-search-sweep-1024x752.png wp-content_uploads_2019_08_simple-curve-sweep-divide-1024x576.png wp-content_uploads_2019_08_simple-sweep-curve-offset-to-origin-1024x576.png
Grasshopper Connection Object Guide - Loft Object
With the Grasshopper - ARCHICAD Connection tool, you can enhance your BIM model with complicated shapes that can not be defined easily with the default ARCHICAD tools. To be able to properly represent and document these shapes, while keeping the geom...
wp-content_uploads_2019_08_loft-object-points-1024x562.png wp-content_uploads_2019_08_Loft-cover-photo-1024x616.png wp-content_uploads_2019_08_object-search-loft-1024x752.png wp-content_uploads_2016_06_Info_18x18.png
Top Contributors
