Design articles
Articles
Stair Tool Basics - Automatic Landing
The new Stair Tool has the feature to add landing automatically during creation of the stair. Landing length can be defined in the Stair Settings under Rules & Standards: Automatic landing can be placed with one click during Stair creation. Start wit...
wp-content_uploads_2017_08_Automatic-Landing-Settings-899x1024.png wp-content_uploads_2017_08_stair_automatic_landing.gif wp-content_uploads_2017_08_Automatic-Landing-Goings-1024x97.png wp-content_uploads_2017_08_stair_automatic_landing_2.gif
Railing Tool Basics - Convert Pattern To Segment Length
This option can be useful for creating different Patterns in a Railing Segment. By default in one Segment one Pattern is repeated (A Segment is the part of the Railing between two Nodes). 'Converting Pattern to Segment Length' makes it possible to ed...
wp-content_uploads_2017_07_rail_convert_pattern-300x225.png wp-content_uploads_2017_07_Convert_Pattern_lenght.png wp-content_uploads_2017_07_railing_edit_mode_palette.png wp-content_uploads_2017_07_selecting_-a_segment.png
apolgar by Graphisoft
  • 336 Views
  • 0 comments
  • 0 likes
Railing Tool Basics - Pattern Distribution Settings
Introduction In the Railing Tool settings a Pattern can be defined. Toprail, Handrail, Rails, Inner Posts, Balusters, Panels can be added to the Pattern, which can be repeated within the Railing Segment. This article describes the distribution logic ...
wp-content_uploads_2017_07_node_posts-1.png wp-content_uploads_2017_07_posts-2.png wp-content_uploads_2017_07_Balusters.png wp-content_uploads_2017_07_divide_segment.png
  • 458 Views
  • 0 comments
  • 0 likes
Railing Tool Basics - Glass Panel Railing
Introduction This article presents how to create a glass panel railing with posts. We used an L-shaped staircase where the Riser Offset is set to 0. In this case only one post will be added by the intersection point of the two flights. Let's start Ac...
wp-content_uploads_2017_07_Screen-Shot-2017-09-07-at-11.18.27-1024x726.png wp-content_uploads_2017_07_edit_pattern-300x272.png wp-content_uploads_2017_07_Inner_Post.png wp-content_uploads_2017_07_TopRail_settings-846x1024.png
  • 2000 Views
  • 0 comments
  • 0 likes
Stair Tool Basics - Custom Tread
It is possible to save elements as Library Object which can be used as custom Treads. Any ARCHICAD element can be turned into a custom Tread Library Object. This article describes you how to create a custom Tread using the Morph Tool. Activate the St...
wp-content_uploads_2017_07_stair_with_custom_treads-300x241.png wp-content_uploads_2017_07_Edit_Mode-300x227.png wp-content_uploads_2017_07_selecting_the-first_step-282x300.png wp-content_uploads_2017_07_Convert_secelction_to-Morph-1024x645.png
  • 1323 Views
  • 0 comments
  • 1 likes
Stair Tool Basics - Bullnose Stair
This article outlines how to model a stair with bullnose steps. To see how to place a traditional railing on it, click here. Activate the Stair Tool and place any Stair of choice (Bullnose stairs are mostly made of wood). Navigate to the floor plan a...
wp-content_uploads_2017_07_bullnose_render-300x289.png wp-content_uploads_2017_07_Bullnose_stair_1-1024x664.png wp-content_uploads_2017_07_Bullnose_stair_2-1024x687.png wp-content_uploads_2017_07_Bullnose_stair_3-1024x705.png
  • 618 Views
  • 0 comments
  • 0 likes
Stair Tool Basics - Spiral Stair
There are two ways to create a spiral stair using the new Stair Tool: using the Magic Wand using the 'Arc by Centerpoint' command from the Pet Palette during the input Using the Magic Wand Place a circle on the floor plan ( Guide Line Segment,Line To...
wp-content_uploads_2017_07_Spiral_stair_Magis_Wand.gif wp-content_uploads_2017_07_baseline_spiral_stair_left-300x251.png wp-content_uploads_2017_07_spiral_stair_Pet_Palette.png wp-content_uploads_2017_07_Baseline_right-300x102.png
  • 8699 Views
  • 1 comments
  • 1 likes
Stair Tool Basics - U-shape Stair with equal flights
Let's place a U-shape stair: Activate the Stair Tool. Open the 'Stair Default Settings' and make sure that the following settings are used (Story height: 3000 mm): Click ok. Click on the floor plan to begin inputting the Stair. Start drawing the stai...
wp-content_uploads_2017_07_Stair_Settings.png wp-content_uploads_2017_07_U_shape_stair.gif wp-content_uploads_2017_07_Pet_Palette_rearrange.png wp-content_uploads_2017_07_Pet_Palette_stretch.png
  • 3855 Views
  • 0 comments
  • 0 likes
Stair Tool Basics - Custom Stair with Steel Beam Support
This article presents you a step-by-step description for modelling a custom stair (designed by Építész Stúdió). It shows how to model the staircase using the new Stair Tool. Things needs to be known about the staircase: Story height is 3400 mm. This ...
wp-content_uploads_2017_07_Stair_cropped-1024x600.png wp-content_uploads_2017_07_GS_Stair_Story_height.png wp-content_uploads_2017_07_Stair_default_settings.png wp-content_uploads_2017_07_Stair_Pet_Palette_Landing.png
  • 1256 Views
  • 0 comments
  • 0 likes
