2020-03-19 12:24 PM
2020-03-19 01:22 PM
n = REQUEST ("Profile_default_geometry", name_or_index, n1, n2, ..., nm, x11, y11, edgeVisible11, vertEdgeVisible11, additionalStatus11, ..., x1n1, y1n1, edgeVisible1n1, vertEdgeVisible1n1, additionalStatus1n1, x21, y21, edgeVisible21, vertEdgeVisible21, additionalStatus21, ..., x2n2, y2n2, edgeVisible2n2, vertEdgeVisible2n2, additionalStatus2n2, ..., xm1, ym1, edgeVisiblem1, vertEdgeVisiblem1, additionalStatusm1, ..., xmnm, ymnm, edgeVisiblemnm, vertEdgeVisiblemnm, additionalStatusmnm)
2020-03-19 01:38 PM
2020-03-19 05:28 PM
Luiscardoso wrote:
My GDL kunfu is almost 0
Well... In this case, I strongly advice you to RUN! As fast as you can!
Now seriously: You could try using the CP you want in a column > edit as you wish > Ctrl+c the column > Paste it in your worksheet as 2d elements. It wouldn't be "Alive", but you could easily edit it in plan and paste it again. Or you can join us in the Wish Session Club (AKA "AC Beggars").
2020-04-01 03:05 PM
2020-04-01 07:10 PM
2020-04-01 07:27 PM
Luiscardoso wrote:No. AFAIK the modifiers are disabled when the profile is used in objects.
Is there a way to place the complex profiles as a 2d object, making it also possible to stretch?
2020-04-02 03:04 AM
runxel wrote:Luiscardoso wrote:No. AFAIK the modifiers are disabled when the profile is used in objects.
EDIT: I am right. Look into the docs for more info.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2020-04-02 06:21 PM
Lingwisyer wrote:
Well... if you do not mind stretching uniformly, you can always use the MUL command.
2020-04-14 12:02 PM
