2d AC made object
I drew up a simple combination 2d (smoke & carbon monoxide alarm symbol) and saved it as AC object. The funny "backwards' S is symbol for smoke and I was able to change the pen for it (after initial creation), but not the line (spline?) thickness which I'd like to do.
AC's generated script below with attachment of how it looks now.
Any help much appreciated.
Thanks
lec
mul2 A/0.445092, B/0.349756
add2 0'-3.4804", 0'-0.0000"
pen 141
line_property 0
arc2 0'-1.0204", 0'-9.2691", 0'-4.5008", 17.13174928742, 342.8682507126
arc2 0'-9.5814", 0'-9.2691", 0'-4.4614", 197.2878921144, 162.7121078856
pen 141
spline2a 6, 2,
0'-0.2263", 1'-0.2304", 0'-0.0000", 0'-0.0000", 0'-0.0000",
0'-2.3697", 0'-11.3211", 931'-4.6484", 0'-1.2842", 0'-0.5513",
0'-1.8943", 0'-9.8447", 737'-8.1960", 0'-0.5577", 0'-0.4834",
0'-0.7830", 0'-8.9270", 746'-8.3605", 0'-0.4826", 0'-0.6500",
0'-0.4623", 0'-7.1815", 971'-3.7383", 0'-0.6420", 0'-1.1214",
0'-2.4103", 0'-6.3833", 0'-0.0000", 0'-0.0000", 0'-0.0000"
define style{2} "AC_STYLE_1" "Arial", 5'-9.4444", 0
paragraph "AC_PRG_1" 1, 0'-0.0000", 0'-0.0000", 0'-0.0000", 3'-3.3701"
pen 1
set style "AC_STYLE_1"
"110V"
endparagraph
textblock "AC_TEXTBLOCK_1" 23'-10.4870", 7, 0'-0.0000", 3'-3.3701", 3'-3.3701", 3'-3.3701",
"AC_PRG_1"
richtext2 0'-0.0000", 0'-0.0000", "AC_TEXTBLOCK_1"
define style{2} "AC_STYLE_2" "Arial", 6'-10.2368", 0
paragraph "AC_PRG_2" 1, 0'-0.0000", 0'-0.0000", 0'-0.0000", 3'-3.3701"
pen 141
set style "AC_STYLE_2"
"CO"
endparagraph
textblock "AC_TEXTBLOCK_2" 0'-0.0000", 7, 0'-0.0000", 3'-3.3701", 3'-3.3701", 3'-3.3701",
"AC_PRG_2"
richtext2 0'-5.5213", 0'-6.1675", "AC_TEXTBLOCK_2"
2 REPLIES 2
Erich
Lec,
You have four pen assignments in the script you show. The first one, before the LINE_PROPERTY command, appears to affect your backward "S" symbol. The second, before the SPLINE2A command should be the one you need to change to change the outline of your symbol. The other two are both related to your text blocks.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Hi Erich
Thanks for your reply.
Turned out to be the pen just before the: spline2a.
Thought I had changed that pen with no luck before posting but maybe I messed up my attempt to change it, probably will never know now.
And thanks for you help once again.
Take care.
Be safe out there.
lec
Learn and get certified!
