NigelPerry wrote:
Im modeling a 3D and have signage but need to input my own fonts which i have downloaded and added to my machine but they do not show in Archicad. How can i solve this?
Do you mean you are using a '3D text' object, and the fonts you have added do not show in that object?
It may be had coded to use just particular fonts.
The 3D text object I have is like this, but you can type a custom text name (so long as it is available in your operating system - i.e. it shows as a standard text font).
Can you see the fonts you have installed in the standard text tool?
If not they are not installed properly in your operating system or you have not restarted Archicad since installing them.
