3D Nuts & Bolts
I need some 3D nuts, bolts, and washers. Does anyone know of any .gsm parts like this?
This is not good enough. I want threads.
Can anyone tell me it this is a GDL script ?
http://softlayer.dl.sourceforge.net/project/boltfactory/Bolt%20Factory%20for%20Blender%202.5/Bolt%20...
17 REPLIES 17
Erich
Steve wrote:
Can anyone tell me IF this is a GDL script ?
Steve,
No it is not.
I think the GDL Cook Book has a 3D bolt script in it. However, I haven't looked at it in a long time.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Yep the cookbook has a script for this. In fact, I recently made a parametric bolt, nut and washer combo based on standard sizes. If someone will remind me on Monday, I'll post it.
Nuge
Steve,
Try this Cadimage object
http://www.cadimageworld.com/downloads/Item/340-bolts
Nuge
AC27 i9 11900K / 128G ram / GTX 3090 / D5 Render
the CADimage bolt I tried wont let me set the dia. to 2 1/2".
Nuge
Steve,
Ask them to open the code so you can add in the sizes you need.
Nuge
Brett Brown
Nuge wrote:
Ask them to open the code so you can add in the sizes you need.Nuge
Should have been fully parametric in the first place.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Check out the fully parametric bolt I just posted to the depository.
too bad I don't have AC 14. 🙂
I could probably take this back to AC12, but not AC10. Your standards in Brazil are probably different anyway.
Learn and get certified!
