Design forum
3D Orbit
Archicad 12
Is anyone having a problem with the 3D orbit function in perspective mode.
Sometimes the centre point of my orbit appears to be so far away it is impossible to orbit around a wall or object im working on. Has anyone else experienced this problem.
Ranked top of my annoyance list this one.
9 REPLIES 9
Hi Bryan
I've not had a problem with 12 regarding that.
This for me has usually meant that I have some object out a ways from model, or so it seems to me.
Someone else may know more.
Bier
Mats_Knutsson
BryanRichards wrote:
Archicad 12
Make a thick marquee around the area you work on and view marquee in 3D.
/Mats
AC 24 SWE Full
HPZbook 32GB i7 7820HQ 2,9 GHz
Quadro M2200 2GB
It seems to use the centre of whatever is selected as the point of rotation. Marquee option is a good suggestion. I noticed if you select an item while in the 3D window and then Orbit it will orbit around the selected item. This can be useful sometimes.
__archiben
... but more often, not.
it went through discussion in the 10 development and was deemed useful, but having used it for two versions (10 and 11) i asked again for it to be abandoned and just have the 3D rotate around whatever you 'grab' when you invoke an orbit: make it consistent!
whilst i received agreement from the designer responsible at GS, it seems to me that the orbit-whilst-something-is-selected function is actually FAR worse than previously.
i can only apologise for starting it, and hope that they ditch it completely soon . . .
~/archiben
b e n f r o s t
Ive used the f5 (3d marque mode) and F3 (3d everything) , that seams irrelevant.
This is what happens.
Nothing selected, cross hair on a column: orientation moves around the closest object the navigation red cross hair hovers over.
Column selected with cross hair on a column: orientation no longer moves around the closest object the navigation red cross hair hovers over. If using F5 mode, the orientation now centres around the middle of the marque
Is this not annoying for anyone? The object of interest is always the abject your working on. So why can i not navigate around the selected object.
Worse still, i can only orientate my camera around an unselected object which has to be accurately aligned to the cross hair. Sometimes the view is so far away, panning is impossible, making it impossible to navigate your object of desire under the cross hair, inevitably making it impossible to rotate around the object your working on without spinning off into ablivion.
Solution.!!!!!!!!!
JUST MAKE THE SELECTED OBJECT CENTRE OF ROTATION or at least give me the option to. Highly annoying when modelling in 3d.
__archiben
bryan - that isn't a robust enough solution: if the selected element is larger than the extent of the zoom in the 3D window, the orbit origin will lie outside of the field of view. that results in a huge gap between the orbit origin and orbit grab point . . . which in turn causes the model to orbit crazily out of view.
the only solution that i believe works is making the orbit origin the same as the orbit grab point: the place that you first click in the model when the orbit command is envoked - be that through the command itself or through temporarily enabling it with the SHIFT-middle mouse button combination.
~/archiben
b e n f r o s t
If your after robust solutions, toggling how orbit works is the way forward. Just like you toggle how marque works etc or how you draw a slab.
Anyhow, i understand what your saying about the large objects, good point, however its not great. Just look at Cinema 4d and adopt that camera solution. It works
PS
How often are you working on an object thats so big it will not fit on the screen? If its a huge slab this can be sliced
__archiben
all the time - i'm usually constantly zooming in and out to pick up the right nodes when modelling in the 3D window.
you're saying i should dice my slab so that the 3D orbit works right? more scissors, cellotope and workarounds, hey?
it just needs fixing.
~/archiben
b e n f r o s t
this is still not an option, correct?
Didn't find the answer? Start a new discussion
Labels
