3D views not showing up
Llian
I had no problem last night going back and forth from plan to 3D views and this morning, there are no 3D views….what did I do?
Lilian Seow
LEED AP | cSBA
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
Try fit in window & then show all layers.
Llian
Thanks. I did show all layers and view extension. No 3D. Only the X, Y and Z coordinates. I had to copy and paste into a new template.
Lilian Seow
LEED AP | cSBA
I solved this problem using the marquee tool. Go to the floor plan, draw the marquee tool and press f4 on Mac or f5 on windows. After you enter the 3D mode, also use the "fit to window" mode, then the model should appear.
