4 panel sliding / pocket door
aahatimo
i am looking for a 4 unit slider that all units slide one way, not split into two pairs like the d4 sliding v15 library object. do not need it to pocket for this project but would be a great option. any ideas?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
11 REPLIES 11
aahatimo
lec,
thanks, that helps a bit.
is it possible to add panels to the 3 panel slider where panels all go 1 direction not to the center?
it will really be great when we have library parts have most instances of doors and windows used in us construction. along with nailing fins and relationships of jamb to rough openings are correct as default.
thanks!
timo
tim hanagan
aahatimo wrote:
lec,
thanks!
timo
1st: Don't know about adding panels, as I've not needed to, just went looking for post relating to your quest.
2nd: Being design/builder in the U.S. for 33yrs, I surely second that one!
lec
aahatimo
still no other options? really need this part! i have tried using the 3 slider version and adding an opening to the open side. the 3door version does not open more than 3 ft.
tim hanagan
Gerald Hoffman
Hi Tim,
I am guessing you are probably trying to do this without going 3rd party library but the CadImage Door & Window Builder can do this door as a 4 panel ( or any number ) slider or pocket. It more than pays for itself IMHO in just what you are experiencing now with lost time and frustration. This is not an Ad.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
aahatimo
gerald,
i had been holding out buying such a pricey ($475 d&wb only) add on for archicad for the past years while on subscription thinking maybe, just maybe, graphisoft would step up and provide increasing better library parts with each release. guess i have been incorrect in my thought process.
thanks for trying to ease my pain!
tim
tim hanagan
Erika Epstein
Why don't you make a wish for this here?
Santa Levente is listening
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
aahatimo
thanks erica, i forgot about that!
link did not come thru,here it is for others:
http://archicad-talk.graphisoft.com/viewtopic.php?p=207025&sid=02f824ecdb61a713f8093d5623a69426
tim hanagan
Hi Tim,
I'm wondering whether you had any luck finding a sliding stacking pocket door that stacks to one side?
Cheers
