45 deg Earth Hatch
cadsph
Does anyone know how to create or download 45 deg alternating Earth Hatch, to represent cut through natural ground/earth?
Please find attached. (The image is of a Structural Footing - AutoCAD)
Regards,
Eduardo Rolon
It is easy to create new "Hatches" in AC, they are called "Fills".
Read:
https://community.graphisoft.com/t5/Document-articles/How-to-create-a-custom-Fill/ta-p/303913
and
https://community.graphisoft.com/t5/Document-articles/About-Fills/ta-p/303850
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
11 REPLIES 11
Eduardo Rolon
Read:
and
AC27 US/INT -> AC08
another Moderator
Erwin Edel
Attached the ground fill that is part of our standard template. I'd assume you have something similar in the template that ships with your version of Archicad.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
The problem with the default on is that it is a two tile texture instead of a four tile, which means you get one set of checks creating continuous lines instead of it alternating in both directions...
Win10 | R5 2600 | 16GB | GTX1660
Thanks, After many iterations - I manged to get the repeating pattern. (See attached)
Thanks for the download, but it's an .XML extension, which is used in Web/ website  applications?
Also, how can I uploaded the file into Archicad and use it as a fill?
Another question:
Now I've created the hatch, how can I export/ download the fill and install into new projects?
With 'Attribute Manager'.
Apologies, I assume too much familiarity with the software. It is with Attribute Manager.
Options > Element Attributes > Attribute Manager
Click on the tab with the Fill icon, on the right side you can 'import' the XML file. If you then select the fill type on the right side you can either append (add it to the bottom of the list in terms of index number) or add by index or by name, which might overwrite an existing fill type in your project.
www.leloup.nl
Windows 10 Pro
Also the exchange format for Archicad Attributes is XML which is not only used for web apps.
AC27 US/INT -> AC08
another Moderator
