Parametric design
About Rhino & Grasshopper and PARAM-O.
A simple question: Window into a wall
Hello all,
I am very new in grasshopper , so I would be very thankful if someone could give me a few tips.
Please see attached image.
Where is my error Just a test to insert a window into a wall.
Thank you,
Hanse
2 REPLIES 2
runxel
Legend
The "orientation" input wants another point, not the "orientation" component (which does nothing on its own).
If you hover over the inputs of a component Grasshopper will tell you what it wants from you. 🙂
It certainly helps if you use the icon view ("Display > Draw Icons") instead of the names...
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Thank you very much, runxel.
Now I have "my" window.
Best Regards, Hans
Learn and get certified!
