AC 15 and coordinates input
Hello!
I noticed one different thing than in previous versions.
In 14 or earlier versions, when I took wall for one of it's ends and start to stretch it and than press shift + "r" than I entered the value for which wall would be extended, but in 15 it goes for a overall length of it. In previous versions that would be the case only if I went with mouse over reference line of the wall and than press "r" and input desired value.
Is there possibility to change that in v15 to previous version?
29 REPLIES 29
cgrimley
I noticed this too. Hopefully its a setting somewhere and it didn't just go away.
Casey Grimley
AC24
iMac Pro (2017) - macOS 10.14.6- 3.2GHz Intel Xeon W - 32GB RAM - Radeon Pro Vega 56 8GB
I was searching for it but couldn't find it.
Probably, wasn't persistent enough.
I think the logic has changed a bit.
I don't think this is something that can be modified by a checkbox somewhere.
However, after you start stretching the Wall, just move your cursor to the endpoint you want to measure the distance from and press ALT+SHIFT. The Edit Origin will move there and the Tracker will display the values you need.
I don't think this is something that can be modified b a checkbox somewhere.
BUT WHY????
why changing something that has been good for years.
This is something that has been working perfectly.
Miha Nahtigal
I have noticed this too. Extremely annoying.
BIMquants.comBETA - Quantities and Costs Estimation with Archicad AddOn :: rushing to publish a beta preview
update on this issue:
presing alt+shift changes things but only for this situation, but it is more complicated than it was.
Is graphisoft on mission to screw their own customers???!!!
one more problem is that alt+shift changes language on my computer and after that operation my keyboard is switched form Croatian to English and my "z" is changed to "y". so undo is not working till the moment I realize that language is switched. ANNOYING!!!!
Yes, seems like a chore having to drag the user origin around to do what used to be automatic.
Has anyone else noticed that the 'Explode into Current View' command does not seem to explode polylines into lines anymore? I used to use this command interchangeably with the 'Unify' command to change lines to polylines and vice versa. But now it seems the operations only go one direction. I can still use the magic wand to place line segments on top of an existing polyline, but must go to the added step of deleting the original.
Laura Yanoviak
I have no problem exploding a polyline into line segments -- do you happen to have Groups enabled?
AC26 US (5002) on Mac OS Ventura 13.5
MarinRacic
Laci,
Who is crazy enough to change things that have been working great for years?? Why break working features? Instead of making things easier for users, you are going the other way around.
Please talk to anyone who is responsible for making this change and make it as it was before in the 1st hotfix.
Thanks in advance!
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
