Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
AC 16 Edu Licesne Renewal
m_ziolo_86
Is it possible to renew license of Archicad 16 Edu after working on this version for last year ? It seems that when the new Archicad version is released, then the newest version is the only one that I will receive license for. Am I correct?
Regards,
M
Archicad 16, Win 8.1
1 REPLY 1
I am not sure, it should be possible. You should contact the main AC reseller in Poland - WSC.
However why would You wish to use 16 while you could use 17?
The only reason I could imagine is 32 bit OS but this could be easily "cured" 😉.
Best Regards,
Piotr
