Parametric design
About Rhino & Grasshopper and PARAM-O.
AC20 Crashes when using CW Scheme in Grasshopper
My Archicad is crashing when i connect the CW Scheme to the Setting component in GS. It first freezes a few seconds then it crashes.
It happends the same with Boundary CW or Line CW.
Units are in Meters, so it should not be an overusage issue.
The only workaround is to adjust the scheme from AC.
Is there anything wrong i am connecting in GS or it might be a bug?
10 REPLIES 10
daviiiiidave
Hey Guys,
did someone test the CW Segment Component in AC?
Im just trying to make an standard CW.
I made a CW, added CW Settings and then i tried to add CW Scheme Settings. But if i connect a BToggle to the Panel Pattern my Archicad crashes.
Someone has any exprience with this?
http://www.directupload.net/file/d/4711/ckhera4v_png.htm
http://www.directupload.net/file/d/4711/9uvxdu7h_png.htm
greetz
Dave
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
daviiiiidave
Same here. I wrote a post 5min ago. [Moderator: post merged into this thread now]
I think its bug because we tried everything we know. Or we are using the CW Component Wrong.
I think it the Panel Pattern Options which crashes the whole thing
daviiiiidave
https://rhinoconnectionbeta.graphisoft.com/viewforum.php?f=9
Can you make also an post here or can i copy yours?
I saw your post on the other forum.
You are right, it is happening when i connect the Pattern inputs.
If there are more experiencing this it might be a bug.
Have either of you contacted technical support, or sent in the crash log if Bug Reporter popped up after your crash? (This is not tech support, but just user chat.)
One of the forum moderators
daviiiiidave
yeah i sent it. lets see what happend. i also wrote in the ac gh connection board.
its really frustrating cause i cant play around! i wanna do some facades but crash master flash is in da house
Which release version are you using ? I have version 5025 but i think there is already a newer one. Maybe they could have already fixed this in the latest update?
daviiiiidave
I got 5025 too.
Still no solution found 😕
Anything new regarding this issue?
