AC23 - Beam Segment: Axis Offset
Hi All,
I am seeking some feedback on whether it is possible to offset beam segments to the parent axis.
e.g. The final segment of a beam would be aligned with the edge of the adjacent segment but be 1/2 the width (a crude L shape if you will).
I can't see a property adjust to achieve this.
I am seeking to replace beams of such a description that have been modelled with a slab; this is important to me as the slab projections are problematic for coordination and for ceiling plan representation.
Thanks for any help.
Regards,
Pete
James B
By using Profile parametric modifiers. then yes.
https://helpcenter.graphisoft.com/user-guide-chapter/85054/
James Badcock
Graphisoft Senior Product Manager
James B
James Badcock
Thanks James.
