AC26 - Layer Selection Usability Fail
DGSketcher
Legend
The Layer selection dialog in tools is now constrained in width to the extent that similar layer names cannot be visually differentiated. You now have to wait 2 seconds for each name to appear in full in a pop up when you hovver your mouse over what you think is the right layer. If you know exactly what you are looking for you can use search, but other than that, layer selection is now a PITA!
Bear in mind this is a function we use all day long! Ever feel like AC is one step forward two steps back...
16 REPLIES 16
bouhmidage
let's start our 27 wish list lol
Archicad 25
Windows 10 professional
Mjules
Mentor
Graphisoft is playing with us!
Martin Luther Jules
AC 10-27 (Full)
Asus | 64 GB RAM | Windows 11
Djordje
Ace
you forgot to mention that you have to right click in order to rename a layer...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
This was reported during Beta stage and is being fixed. I believe for the first update this will be resolved.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
Eduardo Rolon
You sure? 
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Also per Beta, "Click to Rename" is reserved for folders only and it cannot be applied to layer names without a rewrite. So GS decided that renaming folders is the primary activity, not fixing layer names. When you get to the point that you realize that folders are a waste of time then you will have neither renaming.
As a dev indicated it is only 2 more clicks…
AC27 US/INT -> AC08
another Moderator
@Eduardo Rolon, Layer name(s) can be changed inside the folder(s). I am not sure I understand your point. Take a look at the following screenshots:
Martin Luther Jules
AC 10-27 (Full)
Mjules
Mentor
For me, the logic to integrate folders in Archicad is great. This gives a sense of organization. As designers, we have to better organize our layers, materials, and any other objects or structural elements using the software. Furthermore, it works very well on my computer. Try checking this kind of features again, you'll like it.
Martin Luther Jules
AC 10-27 (Full)
Eduardo Rolon
On all versions prior to 26 in order to rename a Layer you only needed to click on the name.
In 26 you need to click on the layer then right click and select 'Rename".
The only item that does click to edit is a Folder or a Master Layer.
This is stupid…
AC27 US/INT -> AC08
another Moderator
