Design forum
AC9 Questions & Answers?
MSotero
Many of us have questions about AC9 and some actually know the answers (GS especially).
Why not use this topic to thread your questions about AC9 and hopefully get some answers here too (perhaps from GS directly).
Here are some initial questions I have (probably more to come):
1) Does the new text editor (word processor) handle multi-column text directly or by import from Word? So we might be able to do sheet specs and other extensive documentation?
2) Can the PM grid system be used/adapted to handle flowing text and auto generate the next sheets? If not, it seems the core technology is already in place given that you can import a .pln file and have it generate sheets now.
3) Given the work flow improvements, has there been any attempt at providing a truly integrated working method of handling typical base sheets for mechanical, electrical, structural, etc drawings?
41 REPLIES 41
Laci Neda
MSotero wrote:
1) Since multi-columns are out, can an entire "multiple page" Word document be pasted into AC and PM?
Although it has now been answered. You can now copy and paste multiple page texts from word into one textblock in ArchiCAD and the original formatting will be retained.
MSotero wrote:
2) Even though you may not be able to answer this question directly.....
Thanks for the thourogh explanation, we will consider it for the future.
László Néda
Architect
Business Development Manager
GRAPHISOFT SE
Haven't seen anything on this so I figured I'd ask:
Can you have a detail in a detail?
Can section marks be linked to existing sections?
These seemed to be popular issues at one time so I just wanted to check if there was any progress on them.
Hello Laci,
I was wondering if the Lightworks integration includes landscaping parts.. trees, shrubery.. etc?
Thanks
Two questions about acv9
From the demo videos I've seen, the new text editor can change existing text blocks in many different ways, but can one do all this new stuff like changing fonts, indents, etc etc "on the fly" as you write the first time around as well ??
Will ACv9 work on WinXP Home or only XP Pro, as indicated in the Software specs.
TIA
Naftali
XP Home
Dwight
Yes. it is live as you go, but like any text editor it is better to place the data first, then format ...
Dwight Atkinson
Some things I got from the following website movies:
http://www.gscne.com/software/archicad9.htm
Top 20 Reasons to upgrade to Archicad 9
20. Ability to search in libraries
19. Copied element to remain selected after copying
18. Can step back with esc key
17. Dockable pallets
16. Can fillet/Chamfer all corners of a rectangle at the same time.
15. Fills and hatches can be applied to slabs, roofs and zones.
14. Text of a imported module can be horizontal or vertical when the module is rotated at an odd angle.
13. View sets can contain a different dimension preference for each view.
12. Importing drawings into plotmaker will place drawings in a preset grid layout.
11. Multi-line drawing names are possible
10. PDF output from plotmaker using publisher.
9. Layouts retain drawing number when publishing.
8. Autocad 12 thru 2004 support
7. Autocad iDrop technology
6. Text Editor
5. Different text styles and colors within the same text block.
4. Individual profiles that can be imported and maintained
3. Lightworks rendering engine with reflections.
2. Dual processor support.
And the #1 reason to upgrade to Archicad 9 (US Pricing)
1. $250 cheaper now rather than later.
Djordje
Mentor
Works on Home too (see my signature)
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Some clarifications...
Not sure what they mean by 'step back', but the new esc functionality is as it should have been all along. If you have selected something and press esc, the selection is cleared. If you have a marquee and press esc, the marquee is cleared. Marquee and a selection, first esc clears selection, second esc clears marquee. Seems innocuous, but try going back to 8.1 after using this (and other similar things) for a while.
This only applies to the LightWorks rendering engine. This is nonetheless good news.
The price quoted by my US reseller is $100 less now than later: $495 until Sept 30, and $595 afterwards if upgrading from 8.1. (Plus shipping / tax.) If upgrading from 7.0 or earlier, the order form shows $790 through Sept 30 and $890 afterwards. Unspecified discounts apply for 5 or more licenses.
[Edited:] Ah, I see from a different thread that your "$250 cheaper" refers to sites upgrading 10 or more licenses since all volume discounting is ending in the US on October 1.
One of the forum moderators   •   AC 26 USA and earlier   •   MacOS 11.6.8, iMac Pro 10-Core, Radeon Pro Vega 64
Is the Text Editor capable of spell checking with in the box itself vs. after text is placed on the plan?
Thanks,
Joseph Harouni
After it is placed.
Laci Neda
Sorry, I'm afraid not.
László Néda
Architect
GRAPHISOFT SE
James Murray
Vote, vote, vote!!!
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
James Murray
With no command in process, selection, or marquee, esc activates the arrow tool. I guess that's as far as it can go. (AC10: more esc'ing gives Close, Quit, Shut down, drive me home...? )
Hey, 200!
James Murray
Question..
Does AC 9 Include 3d lanscaping (Bushes, trees, etc..) for Lightworks? If not where can Lightworks compatible plants be found?
Thanks
Laci Neda
There are some bitmap trees and bushes you can use. See attached picture.
László Néda
Architect
GRAPHISOFT SE
What do you mean by LW compatible, Rashid? (Or better, what would an in-compatible object be?) Anything in your model will render with LW.
The ArchiBAM and other trees from GDL Central render better than the standard (flat) bitmap ones because they apply bitmap folliage to polygons so that shadows are more realistic at all sun angles and fly throughs make more sense.
__archiben
maybe you mean RPC people and trees? as far as i'm aware there is a module for lightworks that does this, but i don't think that it's licensed by GS for archiCAD 9 at the moment . . .
anybody else know more about this?
~/archiben
b e n f r o s t
Dwight
yeah.no.
Dwight Atkinson
stefan
~/archiben
RPC is not supported in AC9.
People in need for RPC editing can try the plugin for Photoshop and add them in post.
--- stefan boeykens --- architect-engineer-musician ---
Archicad26/Revit2022/Rhino/Unity/Solibri/Zoom
MBP2019:i9Octo2.4GHz32GBVega20/Monterey+Win11
ARCHICAD-user since 1998
Dwight
but not mac.
Dwight Atkinson
