Design forum
ADDING LIBRARIES
I want to add a library to my AC file but, i would like to first know if this will this automatically appear in the embedded libraries or in my linked libraries
Cant seem to find whats happening and where it appears when added ? Where do I need to be looking ?
tHX
3 REPLIES 3
If you are adding a single file (object), you can only add those in your Embedded Library.
If you are adding a folder with many objects in it, or an LCF (Library Container File), then those you can only add as Linked Libraries.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Roopa A
How to use linked library.
I need to load .lcf file
Roopa A
Open the Library Manager > Click the "Add..." buton > Select your .lcf file > Click the "Choose" button > Finally: Reload your Libraries.
Didn't find the answer? Start a new discussion
Labels
