ARCHICAD 21 (7000) & 22 (4005) Public Updates Released
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Everyone,
Today we have made the final version of our next ARCHICAD 21 (7000) & 22 (4005) Updates available. We have created and tested packages for the INT, USA, AUS, UKI and NZE versions so far and they all passed our Quality Control. The Check for Updates feature should notify you about the new version already. We will keep testing the rest of the language versions, and release them as they pass our Quality Control.
GRAPHISOFT has been testing ARCHICAD 21 and 22 against the available Beta versions of macOS 10.14 Mojave. Based on our findings, we have also included some fixes specifically for this macOS upgrade, which is going to be released Publicly today as well.
As the Public Release of macOS 10.14 will somewhat differ from the Betas, we recommend early adopters to only upgrade if they have the option to roll back to macOS 10.13. Otherwise we recommend to keep using ARCHICAD on macOS 10.13 High Sierra to avoid any unforeseeable issues. ARCHICAD compatibility with macOS 10.14 is explained further in our related Help Center Article. This article will be updated with newer information once we have feedback from the macOS 10.14 release.
You can read the Release Notes and download the packages from here.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
12 REPLIES 12
After installing and launching 4005, immediately prompted to download 4006. Then:
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Csaba Kezer
Hi James,
It seems your ARCHICAD 22 FULL version with Update Build 4005 has been offered our Solo Updater (Build 4006). This happened due to a glitch in the logic of our Check for Updates service. Needless to say that the FULL AC versions can't use the Solo Updates and you shouldn't have received this second update notification at all. The warning prompt you saw at the second installation is the safety mechanism that doesn't let you install an incompatible update to your existing installation.
We have fixed this glitch now, so the Solo Update shouldn't be visible to you anymore.
Thanks for the catch!
Csaba
Csaba Kézér
Director, Global Customer Support
Robby
I downloaded the update but noticed it said "Solo" on it......they must have the wrong file in place.
Rob Marelli-
AC 26 & 27
MacBook Pro (2021) M1 Max -32 Gb RAM - Sonoma 14
Aha, that explains it, Solo didn't register to me. Thank you.
James Murray
I hope you launch the Spanish update as soon as possible.
bug from preview is still present. you cant delete post in railing edit mode.
workaround is to set them to invisible. but still sucks
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Yes, we couldn't fix it before releasing the final version. We are hoping to finish it for the next update though (build 50xx) - You will find it in the release note as fix #252335 when it is done.
In the meantime, this happens in Floor Plan and 3D view, however it works fine on S/E/IE views and also from the Settings dialog, or (as you mentioned) you can just turn them invisible. You can keep working with that in mind until the fix is ready.
Regards,
GRAPHISOFT
when will the German Version update V22 4005 be released?
Why is that so many days after the other language versions?
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
During testing the rest of the language versions we have found a few things we would like to fix before releasing the update, so it is going to take a few more weeks.
Thanks for your patience. In exchange for the delay, the update will be more stable.
Regards,
GRAPHISOFT
