ARCHICAD 21 (7000) & 22 (4005) Public Updates Released
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Everyone,
Today we have made the final version of our next ARCHICAD 21 (7000) & 22 (4005) Updates available. We have created and tested packages for the INT, USA, AUS, UKI and NZE versions so far and they all passed our Quality Control. The Check for Updates feature should notify you about the new version already. We will keep testing the rest of the language versions, and release them as they pass our Quality Control.
GRAPHISOFT has been testing ARCHICAD 21 and 22 against the available Beta versions of macOS 10.14 Mojave. Based on our findings, we have also included some fixes specifically for this macOS upgrade, which is going to be released Publicly today as well.
As the Public Release of macOS 10.14 will somewhat differ from the Betas, we recommend early adopters to only upgrade if they have the option to roll back to macOS 10.13. Otherwise we recommend to keep using ARCHICAD on macOS 10.13 High Sierra to avoid any unforeseeable issues. ARCHICAD compatibility with macOS 10.14 is explained further in our related Help Center Article. This article will be updated with newer information once we have feedback from the macOS 10.14 release.
You can read the Release Notes and download the packages from here.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
12 REPLIES 12
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Everyone,
After the release of ARCHICAD 22 Update 4005 for the first few languages, we found a few issues related to Parametric Profiles and Hotlink Modules. We would like to fix these as soon as possible, so we created new update packages and we already started testing them.
This means we won't release update 4005 for the remaining languages, but we will start publishing the new update with a higher build number for all language versions once it is ready.
Thanks for your patience.
Regards,
GRAPHISOFT
The Grasshopper-ArchiCAD connection is crashing 22 (4005) every time I click it in the menu.
Does the add on only work for 3009?
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
We have just started releasing a revised version of the 40xx update last week (you can read about this here), and we are still testing the remaining language versions to release them. Once all the language versions have been tested and released, our Quality Control Team can focus on testing the compatible Grasshopper Connection tool version.
When this happens, you will see the "Compatible with ARCHICAD build" column on the Add-on's download site change from 3009 to 4023.
Until then, the tool is only compatible with ARCHICAD 22 build 3009. Thanks for the patience.
Regards,
GRAPHISOFT
