2018-03-28 04:31 PM
2018-04-12 12:50 PM
ejrolon wrote:Hello ejrolon,
and here's another bug.
Open AC
Select Browse for Solo Project
When Finder Window opens hit cancel
AC will freeze.
I expect that I should get Beta Points for testing this.
Last time I install a preview version
2018-04-12 12:56 PM
DGSketcher wrote:Hello DGSketcher,
Has the QA manager at GSHQ retired? AC is becoming exponentially buggy. Not those bugs that crash and you know something went wrong, but a steady stream of irritations and display errors. I just swapped a composite wall type, at which point the door in the wall has changed the zero value I had for "Sill to wall base" to 2040mm so the door is now through the roof. I have a layout that won't recognise the drawing extents to do "Fit to frame" correctly, the whole of the drawing is displayed correctly, but the layout frame is smaller!?. The same view settings work fine on other layouts. I am also getting intermittent wall connection failures where simple composite wall corner connections stop working on plan. And finally automatic dimensions which are sufficiently unstable e.g. moving and vanishing nodes that have forced me to question whether I can trust the "automatic" mode.
Come on GS you can do better than this and you need to with Revit breathing down you neck!
Rant over... for now.
2018-04-12 01:47 PM
2018-04-13 03:06 AM
dkovacs wrote:Right now with major blackout in Puerto Rico but I’ll try to reproduce it to see what might be different.ejrolon wrote:Hello ejrolon,
Open AC
AC will freeze.
I tried it on several Macs, but I just couldn't reproduce this. Did you happen to find out anything about this? maybe there's something specific about the folder it opens in or something similar? Did anyone else experience this?
I know it can be a pain, but I really appreciate that you take the time to not only install the preview update, but also give feedback. This really helps a lot for us to release a more stable update in the end.
Thanks,
another Moderator
2018-04-13 03:56 PM
2018-04-13 11:34 PM
2018-04-15 08:35 PM
2018-04-19 07:29 PM
Takis wrote:Hello Takis,
Hi, I am facing the following issues:
1. Graphics issues:
After a working around for about 2-3 hours, a lot of drawing things disappears from screen. Restarting Archicad resolves the issue for the next 2-3 hours.
2. Railing object causes crash:
If associated railing is selected and click on "Use display settings of associated stairs", Archicad crashes.
Takis.
2018-04-19 10:46 PM
2018-04-19 11:03 PM
dkovacs wrote:Tried it today after the second major blackout and couldn't reproduce it.ejrolon wrote:Hello ejrolon,
Open AC
AC will freeze.
Thanks,
another Moderator
