Design forum
ARCHICAD 24 Update 6001 Preview Released
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
We have made available the latest Preview version of Archicad 24 Update 6001. We have created and tested packages for the INT, AUS, NZE, UKI, USA, GER & AUT language versions.
The Preview Update is only available for the above language versions. If you attempt to install it on a different language version, you will get an error message about this.
We will create Public Update packages for all languages in the upcoming weeks. It will be possible to update from the Preview package to the Public one without a problem.
You can read the Release Notes, List of Improvements and download the packages from here.
Should you have any questions or feedback, please let us know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
21 REPLIES 21
DGSketcher
Champion
Three launch crashes. Reboot. Crashed again. Start up file list still on screen.
AC24-2021-05-27-10-35-40-3948
Mac OS X 10.15.7
Initial part of Apple Crash report contains...
Time Awake Since Boot: 50 seconds
System Integrity Protection: enabled
Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [522]
Apple iMac macOS Ventura / AC26UKI (most recent builds)
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for your report!
As of this morning, we received a similar report about this crash. The issue comes from RFA and RVT Geometry Exchange add-on. Currently, by removing this addon, Archicad won't crash at startup. I'm investigating whether this is the bug with the update or with the add-on. Once I know more about it, I will let you know!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
DGSketcher
Champion
Hi Minh,
Can I just delete the RFA and RVT Geometry Exchange folder in add-ons to get going again?
Trevor
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Trevor,
Yes, that should do the trick!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
DGSketcher
Champion
Thanks Minh, AC launched. Bit of a beach ball delay but on reflection I think that's normal on first launch.
I had the same issue on my windows machine. deleting that folder worked for me as well
DGSketcher
Champion
Beam length stretching in 3D is broken in this update. You can move the endpoint as a workaround, but you can't simply extend the beam along its axis. This appears to be a legacy data problem. Creating a new beam in a new file works ok. I have a sample beam that fails trapped in a .MOD file if GS would like me to upload it.
Most probably you did, but did you check if the beam is in multi segment mode and the segment is locked?
DGSketcher
Champion
None of the above. Bit strange this one as I can create a new beam in my current project with 6001 and it fails, but in a new clean file it is ok. Even adding a new beam in the MOD fails
Didn't find the answer? Start a new discussion
