Design forum
ARCHICAD Crash in Door/Window Tools on Windows 7 due to MS Update
NCornia
Hi All,
Multiple users on Windows 7 reported that multiple versions of ARCHICAD would crash whenever they opened the Door or Window settings dialogs. It is caused by Security Update for Windows 7 (KB3097877) released this Tuesday, November 10th. If you do a web search you will find that this update is problematic for a number of applications. You may uninstall this single update or perform a System Restore to make ARCHICAD function normally once more. Read more here:
So far it appears ARCHICAD on Windows 10 is not affected and we will conduct tests on ARCHICAD on Windows 8/8.1.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
3 REPLIES 3
I did a system restore that fixed the issue with Archicad & Outlook.
The update is trying to install again, is there a way I can stop it from installing? Or trying to install.
NCornia
Rogerdodge,
. We have updated our Help Center article with instructions:
Best regards,
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
I can confirm that the re-issued update for the broken update (KB3097877) is working fine.
The confusing part is the re-issue has exactly the same number as the broken one.
I manually un-installed the update (re-started) then checked for new updates and re-installed and restarted again.
I assume that given enough time the new update will automatically install if you have the updating set to automatic.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Didn't find the answer? Start a new discussion
