Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Accidentally modelled in wrong measurements - Absolute newbie
Hi there,
I've learnt how to model a site model for a project which includes a slope. I have accidentally modelled using the wrong measurements but is still to scale. i.e. 10metres as 100 000mm instead of 10 000mm. Essentially, I've added an extra 0 to every measurement. (silly mistake )
I have tried using the resize tool by highlighting all the elements and defining it again graphically, however, this only changes the measurements in the horizontal plane and not the vertical plane, so my slope becomes very steep.
How can I resize the entire model in 3 dimensions?
Thank You.
Eduardo Rolon
I don't think you can.
The correct answer is to remodel it, that way you might pick out any other newbie mistakes.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
1 REPLY 1
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
