Add ability to hide windows and doors without hiding their host walls
Professor Pickle
Sometimes I need to show just the walls, without the windows or doors. Currently there is no way to do this. If I hide windows/doors that also hides the host wall. I'd like to be able to hide windows/doors without hiding their host walls.
This wish is particularly important if you work a lot, like I do, with prefabricated and panellised walls. I have a workaround for this but I don't like it as it imposes extra work and as with all workarounds I have to be careful not to break it.
Pushing the boundaries of local time/space continuum since 1972.
Archicad 26 | iMac (Retina 5K, 27-inch, 2017) | 4.2 GHz Quad-Core Intel Core i7 | 24 GB | Radeon Pro 580 8 GB | macOS 12.6
Hi @Professor Pickle, I’m sure You can hide W&D in floor plan via Document > Model View > Model View Options > Construction Element Options then from Door and Window drop down list choose Hide on Floor Plan.
In 3D View you can hide them via View > Elements in 3D View > Filter and Cut Elements in 3D then from ( Element Types to Show in 3D ) uncheck Door & Window, I hope it helps.
AC 27 INT 5003
Stuart_Clark
This is already possible using the Model View Options filter in Archicad.
AC 27 INT 5003
This is exactly what I wanted. I always forget about that 3D filter. Thanks!
