Rather than bringing in a multi-storey hotlink you can bring in each storey as a separate hotlink.
You then place these in the storey of the master that best matches (although that really doesn't matter) and then manually adjust the height of the hotlink so it all looks normal again.
Or you can save as a GDL object and just add that object to your other file - a morph should work as well.
