After create opening, the opening finish of the lower wall and the location wall is different.
LeeJaeYoung
I want to do it together, what should I do?
If not, what should I use instead of create opening?
It consists of two walls on the first and second floors.
AC27 on window 11
6 REPLIES 6
Do you mean you need to create one opening that penetrates the two walls n first and second floors?
AC 27 INT 5003/WIN 11
yes
Ask for a wall for each floor.
AC27 on window 11
You can place opening from opening tool and define its sizes and the geometry method ( here horizontal) then by hovering over your wall seeing how it will look click to place the opening.
You know what I want to put together because this part is different, right?
AC27 on window 11
I draw all walls like that as two story walls. Much easier and likely how it will be constructed.
A more detailed and lengthy explanation is needed.
I have to use translate.google.com, so the translation doesn't make sense for sentences that are too small.
If you use images from time to time, I would be more grateful.
AC27 on window 11
Learn and get certified!
