This isn't a scheduling issue, but an issue with working with library parts, so I'm moving this to the Library Parts forum...
If you want to use the standard AC windows and doors, you have the option of using the Favorites feature, creating a named Favorite for each of your predefined types. Another option is to use visual favorites - walls that have your windows/doors pre-placed in them that you can then eyedropper to pick up their attributes.
The idea of having groups of pre-defined parameters for glazing, opening type, etc is beyond what is reasonable to re-program with the Graphisoft objects due to their dependence on complex, deeply nested macros. But... that approach is exactly what is done by the Cadimage Door/Window product, so you might want to do a 30 day free trial of it to see how it handles things.
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
