Annoying Archicad
This thread is for those things Archicad does that during the daily grind makes one clench their teeth.
This is not meant to be a wish list, but a place to tell the devs what where and how Archicad causes frustration while using it (and maybe a place where "bad" behavior can be explained if there is a reason for it).
52 REPLIES 52
And we still can't use the Roof Maker tools in the 3D view !?!
the intermittent and unpredictable response/lack of response to keyboard input when selecting objects and invoking keyboard shortcuts to act on them.
The Drag a Copy or failure to Drag a Copy takes a lot of time out of my day and a fair amount of soul sauce.
My keyboard works well enough to type this note. Why does it not respond to my touch in ArchiCAD?
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
1) AC seems to prefer to select invisible elements (i.e.: marker extent line, things that are concealed behind slabs/fills) over things that are immediately visible and directly under the spot that I've clicked. Yes I know I can hit tab to cycle through, but why would I do that if there is only one object (the one I want to select) visible where I'm clicking?
2) Why can't AC figure that if I click near the edge of an object (slab, zone, fill, etc.) to edit it, that I'm more likely to want to edit the edge (i.e.: offset the edge), and not default to move the object. Similarly, if I click near a node, it's obvious that I'd want to edit the node.
3) Why can't zones be visible in section, and above home storeys? That would save a lot of time labelling rooms in sections as well as voids above double height spaces.
