Design forum
Arch Doors doesn’t not cut wall properly in 3D
tranthainguyen
Hi all,
My Arch Door does not punch the wall in the right shape. Instead it punches a rectangle void through the wall regardless the arch.
Does anyone know why?
Thanks heap.
NGUYEN Tran
Architect & Urban Designer
www.syntaxpd.com
Imac 27" Core i7 2.8ghz l 4Gb Ram
MacPro 2011
AC 18 & 19 AUS
4 REPLIES 4
if this is an object you built yourself then you will need to define the wall hole using the "wallhole" or "wallniche" functions in the 3D script. The automatic wall hole only does rectangles based on a,b.
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
Did you create this door frame yourself by saving slabs as a door object?
If so you forgot to add a slab to represent the arched wall hole (i.e. an arched shaped slab with an ID of WALLHOLE).
https://helpcenter.graphisoft.com/knowledgebase/25570/
If it is not an object you have created, what object is it?
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
tranthainguyen
I believe this is an door object from AC20 library.
That’s why I am so surprised why it does not punch the wall correctly.
I will check the library again tomorrow, when I am back to the office. Maybe I will need to re-download the original AC20 Library.
Thanks
NGUYEN Tran
www.syntaxpd.com
MacPro 2011
AC 18 & 19 AUS
What is the exact name of the Door library part? From the name, it is easy to see whether it is a default GS library part or not.
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Didn't find the answer? Start a new discussion
