Design forum
Arch Top Window without upper transom, but as a double sash window
Hello!
I work with ArchiCAD 20 and 21 international and hungarian versions.
I would like to use an Arch Top Window without upper transom, but with double sash. If I turn out the upper transom, I can't choose Double Sash at Main Sash.
Is there a simple solution to this problem?
Thank you, Timea Szabo
0 REPLIES 0
Didn't find the answer? Start a new discussion
Labels
