Design forum
ArchiCAD 13 Hotfix now available!
Greg Kmethy
Dear Talkers,
ArchiCAD 13 Hotfix-2 (build3235) is now available. The name is Hotfix-2, but this is the first hotfix generally available. Please make sure to read the release notes:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC13-3000to3235-ReleaseNotes.html
This Hotfix will update ArchiCAD, the BIM Server, the BIM Server Manager, and all ArchiCAD components, like MEP Modeler, EcoDesigner, C4D Add-On, and the goodie tools.
Teamwork users: Make sure that the BIM Server and all the ArchiCAD clients are updated at the same time!
Gergely Kmethy
Director of Customer Support Services
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
19 REPLIES 19
Brett Brown
So the "Update Archicad" in the help menu is obsolete now? Mine is saying "up-to-date" build 3000.
But in the release notes of this hotfix it updates all Language Versions.
So we have to download the Hotfix from the release notes link now?
Imac, Mojave, AC 20, AC 25 Solo UKI, Vectorworks Architect 2021, Revit LT 2021
aahatimo
brett,
it may be there is not a localized version.
worked for me w/ us version via help menu, but was not automatic when i opened ac13.
edit: i do get the same version when i click on update from release notes though.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Ben Cohen
Hi Greg
I am having trouble updating my BIM Server. Its installed on a separate drive (not on C:), the hotfix cannot find it, but even if i redirect to the installed directory E:\Program Files\Graphisoft\BIM Server\TeamworkServer the installer cannot find the BIM server. This is rather urgent as I have already updated a few of the client machines....
Thanks
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Ben Cohen
never mind, found the BIM server - all good
Ben Cohen
Mac and PC
Greg Kmethy
Brett,
Hotfix has been not verified for NZE version of ArchiCAD yet. We are adding localized versions as QC progresses. Expect NZE later this week/early next week.
Gergely Kmethy
Brett Brown
Thanks Gergely
mdaltezza
Ever since our hotfix, we have been having issues with accessing the bim server libraries. We are unable to upload any new libraries, and while in a project, cannot attach any library at all. Through Archicad, no library on the bim server is visible, while on bim server manager all libraries can be seen.
We have tried reinstalling the bim server software to no avail.
We are all on intel macs running the latest snow leopard builds. The server is running on a dell machine.
Any ideas on how we can fix this?
marlon
mdaltezza wrote:
Ever since our hotfix, we have been having issues with accessing the bim server[...]
Did You update the Bim Server? (the same update patch does that)
Best Regards,
Piotr
mdaltezza
Yes, everything is updated. If it were not, we would not be able to connect to it at all. We have further tested it on the single PC we have in the office. The PC is able to see all the libraries on the server. So it seems a mixed environment is not allowed with the new hotfix. Can anyone else confirm this?
Best Regards,
Piotr
marlon
andrewzarb
I'm using the hotfixed AC13 on Mac OS X 10.5 and I cannot upload any libraries to the BIM server and when I create a Teamwork file no BIM server libraries are created.
ksymons19
Ben wrote:
Hi Greg
Thanks
Ben (or anyone else), care to share how you were able to resolve this issue? Since the next post says you got it. I am just now dealing with this issue with our BIM Server located on a 64-bit Windows 7 server. It's located on the C: of the server but still says not found even after I locate the right directory being C:\Program Files\Graphisoft\BIM Server\TeamworkServer.
Thanks!
ArchiCAD 14 US
ArchiCAD 15 US on Windows XP 64-Bit
BIM Server on Windows 7 64- Bit; Windows Server 2008 R2
mdaltezza
Ladies and Gentlemen,
I hope this helps. As for the Library issue, I have just found out that the IP address of the server allows me access to the BIM Server Libraries.
Another test would be to create the Teamwork Link File on the server side and using that file to connect on the desktop archicads.
Good luck!
marlon
Ben Cohen
Thanks!
We had been having trouble with the box the BIM server is on, I just had to reboot and it worked. I dont think that machine had been rebooted since the BIM server was first installed on it.
Ben Cohen
Mac and PC
Steven Dumont
gkmethy wrote:
Dear Talkers,
Attached is my ArchiCAD build information. Can anyone tell me if I need to update? It keeps on saying I'm not up to date, but when I download and go to install, it cannot find ArchiCAD for some reason. From what I can tell, I already have installed this update previously (one of the few countries to get it early), and the message telling me I'm not up to date is erroneous...
Mac OS X 10.13.6
27" Retina 5K iMac
16 GB Ram
AMD Radeon R9 M295X 4096 MB
AC23, latest hotfix, USA Full
You must have modified something about your AC program folder, whether renaming the application/exe, moving it somewhere else...or?
If not obvious what is non-standard, you might have to re-install.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6.1, iMac Pro
Steven Dumont
Sorry, confusion on my part!
The trouble I am having is with the new library update (3479.147). I download the file and go to install it, and it says it cannot find the AC13 library, so I manually browse to find it, and it still will not work.
Mac OS X 10.13.6
27" Retina 5K iMac
16 GB Ram
Steven Dumont
As you can see, I have everything located where it should....
Mac OS X 10.13.6
27" Retina 5K iMac
16 GB Ram
Stress Co_
Looks like you added "13" to the "Archicad" application (so you could differentiate it from other versions in the doc??). Rename it "Archicad" and it should work.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.14.6 (Mojave)
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 48 GB 2667 MHz DDR4
Graphics: Radeon Pro 580X 8GB
ArchiCAD 24 (3022 USA Full)
Steven Dumont
AH HA!
Thanks
Mac OS X 10.13.6
27" Retina 5K iMac
16 GB Ram
Didn't find the answer? Start a new discussion
Labels
