ArchiCAD 15 Hotfix-4 (Build 3898)
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
ArchiCAD 15 Hotfix-4 package (Build 3898) for BIM Server and ArchiCAD15 has been released today. The INT, USA, AUS, NZE, GER language versions of the Hotfix are available through the automatic update system today, while further versions will be released as they pass Quality Control. Please note that with this hotfix Deployed Installation is also possible. You can read more details about it in the release notes along with the list of fixed bugs:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC15-3632to3898-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
6 REPLIES 6
I have tried to use the latest hotfix on my machine.I have tried several times to update and everytime the installer crashed about 70% through progress. Do you have any thoughts on how to get this to work.
All other updates have worked ok to date.
Regards
Iain Thomson
MAC OS X
3.2 GHZ Intel Core i3
4GB 1333 MHz DDr3
Karl Barker
Have applied hotfix 4 and appear to have an old issue rear it's less than pleasant head again.
Here is the test:
Draw a simple building.
Select half of it in Plan in a marquee & viewed it in 3D
Place an object and moved a wall
Then back into Plan
Clicked undo and it goes back into 3D view & undoes what was just performed
Then go back into Plan & everything inside the plan is selected.
I recall this was an issue earlier, but has come back to haunt me again.
Same issue in plan only as well.
Try it.
Have a marquee on the plan.
Delete something outside the marque.
Undo.
Everything inside the marquee should now be selected.
Karl Barker.
27" iMac 3.6 Ghz Intel Core i9
32 Gig Ram
Mac OSX 10.14.6
AC 5.5 - AC22 (NZE)
March_ Bruce
I just wondered if anyone else is having %CPU issues on the mac - fan & cpu load after the hotfix have gone way up for me per the attached, with several outright hangs?
Thanks!
March_ Bruce
attached is another image
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
Hi Karl,
Thank you for the steps to replicate the problem. We'll investigate the issue and get back to you soon.
Regards,
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
Dear Bruce,
We could not replicate such a problem. Our colleagues will contact you very soon for asking for more details and trying to find out what the problem could be.
Kind regards,
AndorSzőke
Product Management
GRAPHISOFT SE
