Design forum
ArchiCAD25 Door Leaf Undercut: Parameter not available?
JDR_SBDC
The leaf undercut parameter seems to not be visible for any door - I have been searching through the "Tool Setting Dialog Boxes" thinking that maybe this parameter was hidden by default - but I have turned them all on to "visible" and I still don't see the parameter available in any of the doors
I am beginning to wonder if GS moved this parameter elsewhere or removed it? I am fairly new to ArchiCAD and have only seen posts related to the door undercut from 2+ years ago
AC25 USA
Windows 11
16 GB RAM
8 REPLIES 8
Mahmoud Qenawi
It's available for hinged and rotating doors via the  door settings and opening tab then frame and leaf dialoug window:
AC 25 INT 3002
Maybe it is something that was done in the creation of our companies template/libraries/work environments? I attached a screenshot - this is a hinged door but is not classified or titled so in the Library
AC25 USA
Windows 11
16 GB RAM
I also just downloaded these doors from the global library, still having the same problem even though these are actually classified as hinged doors
I appreciate your time!
AC25 USA
Windows 11
16 GB RAM
You are welcome,
which Local version you use? I think it’s not the INT one, the library maybe different.
AC 25 INT 3002
Lee Hankins
Mentor
I use the UKI version and I don’t believe that has the setting for undercuts on the door leafs. It is something that would be very useful though.
Lee Hankins
ArchiCAD 4.5 - Archicad 26UKI Apple Silicon 4032
macOS Ventura (13.2)
I believe its the USA version as that's where I am located. Is there anyway we could get an answer from an Admin about why some libraries do not come equipped with the leaf undercut paramter? Seems strange...
AC25 USA
Windows 11
16 GB RAM
@Laszlo Nagy  I have seen you provide some helpful insight on other posts - anything for this?
AC25 USA
Windows 11
16 GB RAM
Mahmoud Qenawi
 Also @Eduardo Rolon is using US version, I hope he can help you in this issue, I'm sorry I can't help.
AC 25 INT 3002
Didn't find the answer? Start a new discussion
