2023-01-24 11:28 AM
The leaf undercut parameter seems to not be visible for any door - I have been searching through the "Tool Setting Dialog Boxes" thinking that maybe this parameter was hidden by default - but I have turned them all on to "visible" and I still don't see the parameter available in any of the doors
I am beginning to wonder if GS moved this parameter elsewhere or removed it? I am fairly new to ArchiCAD and have only seen posts related to the door undercut from 2+ years ago
2023-01-24 11:46 AM
It's available for hinged and rotating doors via the door settings and opening tab then frame and leaf dialoug window:
2023-01-24 11:56 AM
2023-01-24 12:06 PM
2023-01-24 01:07 PM
You are welcome,
which Local version you use? I think it’s not the INT one, the library maybe different.
2023-01-24 11:18 PM
I use the UKI version and I don’t believe that has the setting for undercuts on the door leafs. It is something that would be very useful though.
2023-01-25 06:02 AM
I believe its the USA version as that's where I am located. Is there anyway we could get an answer from an Admin about why some libraries do not come equipped with the leaf undercut paramter? Seems strange...
2023-01-25 08:44 AM
@Laszlo Nagy I have seen you provide some helpful insight on other posts - anything for this?
2023-01-25 09:46 AM
Also @Eduardo Rolon is using US version, I hope he can help you in this issue, I'm sorry I can't help.
