ArchiCad 7 and os x panther
does archicad 7 run under mac os x panther?
I am using a 400 mhz g4.
2 REPLIES 2
yes - very well
If you need to run more then one then you must place the 2nd copy outside the application folder
fuzzytnth3
Adalbert wrote:
yes - very well
I have two copies of ArchiCAD set up and working fine but they are both located in the Applications folder.
I am using 10.3.1. Previously with 10.2.8 trying to run two copies tended to be a bit wobbly but I've had no problems with 10.3
Using AC25 5005 UKI FULL
Learn and get certified!
