Archicad 11 INT (1086) Library Update
Hello everybody.
I've recently installed AC 11 INT and updated with 1086 hotfix. When I try to update the library, I get the message "There is no library update available".
(my .lcf file dates from may 2007) What can I do to make it work? Is this a bug or maybe there isn't an update for the INT version?
Thank you in advance.
Adrian Tudoreanu
2 REPLIES 2
You can't make it work.
There's no INT library update available for the time being.
Message is correct, no bug involved...
Do you get specific error messages while working in AC11?
I see. Thank you so much for your support.
About specific error messages, I must say that until now everything works fine (but I've only installed AC 11 two days ago).
Learn and get certified!
