Stephen wrote:
I just opened our customized Archicad 16 template and saved it as a 17 template. Are there any disadvantages to doing this-should I start from scratch with a new template with our custom layers, fills, favorites, etc.?
Layers, fills, materials, etc, will all be OK.
But you will want to have a look at the new Building Materials and make sure they are set up properly.
Also check your composites and complex profiles that they are now using the correct Building Materials.
The Work Environment that LEW mentioned is another matter.
You will either want to start with the default 17 WE and customise it to suit you or use your old 16 WE and try to find all the new commands and menus to add to it.
Versions 6.5 to 25
