Archicad 22 - How to make a "wallhole" in a custom door?
rob2218
Seems I can't find the "classificaiton" change location (it's locked now to some variable from a list) where I used to be able to change the classification of a "slab object" and convert it into a "wallhole" so's it would cut out the custom hole for windows and doors..............NOW I can't? What gives?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
1 REPLY 1
I don't believe anything has changed here. It is the ID field (which is probably / should be visible in your Info Box) that needs to be set to "wallhole". ID is never locked that I know of.
https://helpcenter.graphisoft.com/user-guide/76690/
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Learn and get certified!
