Hi, I’m not sure if this topic should be in other section.
I’m structural engineer, user of ArchiCAD. I’m Spanish. I specify this because the most used structural software (two of them) are quite different from other countries. And this is because they generate the analytical model from the physical model. So, users of those software don’t really need the new features to generate the analytical model, in ArchiCAD.
But the reason I am writing this post, is because I am really surprised with the concept of “one team, one model”. I don understand it, I don’t intend to use it. But maybe, I haven’t understood. Let me try to explain myself.
If I have understood the workflow, physical model is responsibility of the architect. Is that it? If the proposed workflow is like that, how can this work? Structural design, before structural analysis should be done by the structural engineer (if there is one). So, do architects and engineers modify the same elements from the physical model? Isn’t this dangerous? I don’t see how engineers could design the structure, modifying slabs that architects are working with. We need to place beams, adapt slabs to those beams, and only then, the analytical model could be generated. Is this proposed to be done, in the same model?
Moreover, how do they manage, architects and engineers, to work with column’s floor plan display, if this configuration depends on the element, instead of the views. For example, If I want to show columns of story 1, and beams and slabs of story 2 (usual structural representation), I need to define “One story up” in “Floor plan display”, but this won’t work for the architect.
Haven’t I understood something?
Thanks!
ArchiCAD user since November 2109
AC24, Windows 10
