Archicad 24 - Stair landings - tried everything on how to adjust the landing
rob2218
trying to create a simple "L-shaped" stair and having trouble with the landing settings from the point of the treads edges. (see attached)
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
5 REPLIES 5
4dProof
try clicking the stair ref line on the landing node, select the "turning type options" on the pet palette, and redefine there for the "entire stair" (screen shot attached).
I'm not exactly sure why that works and the stair settings done, and sometimes its the opposite... and then again, sometimes neither works and you ahve to set it in the stair settings, eye drop the placed stair and place a new stair completely
ryejuan
do you intend to have something like this?
In the end what is your Objective?
ArchiCAD 9 onwards
AllanP
or is this what you want?
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 27
Member of Architalk since 2003, but missed the migration to Graphisoft.
(where have all my original posts gone?)
Allan,
that’s exactly what I’m in need of. How did you make that work?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad almost works, but you have to manually edit the width of the stair to get the zero landing.
This is a common situation on most stairs for L-shape and U-shape landings in Volume Detached Housing in Oz.
