Archicad 25 - Crashing
ST_AUS
Hi There,
I am experiencing significant crashing when performing certain functions. The most common occurrence for crashing is closing a tab window. Without fail, every time I attempt this, the file crashes. I've submitted case reports each time this has happened.
Any idea how this can be fixed?
I am on Mac Monterey 12.3.1, in Australia, using Archicad 25 downloaded in April 2022
lparke
This was a known bug for a while.  You might try checking to see if the latest hot fix is installed.  Go to Help menu > Check for updates
ArchiCAD v27 (since v11)
MacBook Pro M1 Max, 64GB
macOS Sonoma
You may not to be up-to-date, as mentioned by lparke.   You show MacOS 12.3.1, but 12.4 is the current release... with 12.5 arriving "soon".  While you downloaded AC 25 in April, did you install the 5010 update?  Check Archicad > About to see what build you are running and update if not on 5010 yet.
https://graphisoft.com/us/resources-and-support/downloads?localization=AUS&type=AC&version=25
One of the forum moderators
ST_AUS
Thanks for your advice Karl and lparke.
