2021-07-30 03:02 AM
2021-08-26 02:45 PM
2021-08-30 03:35 AM
2021-08-30 03:47 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-09-05 06:04 PM - edited 2021-09-05 06:06 PM
Thanks for your clarifications around this new GS ID setup - clearly there are bigger things in store for future releases.
Can you please clarify the following statement:
What will happen if Archicad is not authenticated within 30 days?
Once the 30-day sign-in period expired, file-saving and Teamwork function will not work. Archicad will run in Demo mode.
source > https://community.graphisoft.com/t5/Setup-License-articles/Graphisoft-ID-FAQ/ta-p/304176
Seems to me that this does affect the operation of a properly licensed Archicad instance... since even though you have a license you can not use it to save your files or use TW after the 30 day period?
Unfortunately, this is reminiscent of the ill-considered changes made to the Bug reporter, which since AC24 needs to be force quit to not send your report.
Looking forward to your reply.
Daniel.
