Archicad 2D tree display
Marian Pristavu
I’m having problems with the archicad 2D library trees in both plan and elevation view when trying to use the image display.
I can see the image but there is also a fill around the object - you can see in the screenshot.
Do you guys know how to get rid of that fill?
Thanks,
Marian
2 REPLIES 2
felcunha
Hello,
Maybe the ID of your fill has changed after having migrated or made a fusion with another project.
Go to the Attributes Manager and check which fill has an ID of 65.
Another option is to change the cut fill for another one in the Floor plan and section part of the object's settings.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Marian Pristavu
Thanks for answering.
Indeed that was the problem, but I wonder how did this happen.
We’ll try to find what caused the fill to change the ID number
Marian
Learn and get certified!
