Archicad Grasshopper Live Connection won't connect even with empty file.
HSA Architektura
Yesterday I was working with a file in grasshopper, it was connected and working,
today Rhino 6 asked if I wanted to update it so I did that.
After doing that when I tried to connect between programs Rhino freezed and never woke up.
Same thing happens whith an empty .gh file.
I feel helpless, as I've had to finish a simple task with already set up algorithm, and here I'm 6h later trying to reinstall everything.
Unfortunatly I was trying to connect on the other computer, but on it rhino 6 crashes when trying to connect, to Grasshopper empty file.
Are you on a Mac or a PC?  If you are on a Mac with Monteray and using Archicad 25 v4013 or higher there is a known bug.  See this link.
https://community.graphisoft.com/t5/Setup-License-forum/Grasshopper-Archicad-Live-Connection-I-can-t...
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
www.codearchitecture.com.au
NOM ARCH VIC ARB: 17939
Archicad v26, Mac Mini INTEL 64GB, AMD Radeon Pro
Please contact your local Archicad reseller to put a request through to Graphisoft HQ to let them know you are also having an error.  It might help Graphisoft HQ eliminate scenarios and help find a solution for us all.
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
