Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
Archicad Thermal Bridge Simulation is missing from context menu.
Hi, i am having a problem lately with the thermal bridge simulation option. It does not show up in the context menu. I don't know if this is an update and the option is found elsewhere or if it's missing completely.
I hope someone has some answers for this because it it's a very useful feature. Thank you !
I've moved your post to the Sustainable Architecture forum, which is the dedicated place for ARCHICAD energy evaluation / EcoDesigner...
See the table near the end of this document that lists the capabilities of ARCHICAD itself vs the (extra cost) EcoDesigner STAR license:
https://helpcenter.graphisoft.com/guides/archicad-21/collaboration-guide-for-archicad-21/energy-anal...
Only EcoDesigner STAR performs thermal bridge simulation. Do you have an EcoDesigner STAR license?
http://www.graphisoft.com/archicad/ecodesigner_star/
One of the forum moderators
Hi, and tank you for quick replying. Indeed, i was working on an unit that didn't have the licence to EcoDesigner Star. I found out i was working on another PC before that had all the licences bought .
Thank you again for answering !
