Array with numeric value
i'm trying to make my first gdl script for a rainwater tank in Archicad. I'm able to change the text in the object after people select a predefined value but I also want to change the size of the object according with the tank size.
I defined an array but when i try to adjust the size I get the following error: Numeric type expression required at line 77 in the 2D script of file ....
I tried deleting the quotes but then there's an error in the array. I tried the ABS() function, but that didn't work either. I also searched the GDL reference guide but couldn't find anything.
Can you guys please take a look at my code?
Thanks in advance!
!   Name     : 17.71 regenwaterput.gsm
!   Date     : dinsdag 3 januari 2017
!   Version  : 1.00
!   Written by GJS
mul2	A/2.150000, B/2.150000
DIM typePut[][]
	typePut[1500][1] = "1500"	!inhoud
	typePut[1500][2] = "-.75"	!straal
	typePut[2000][1] = "2000"	!inhoud
	typePut[2000][2] = "-.75"	!straal
	typePut[3000][1] = "3000"	!inhoud
	typePut[3000][2] = "-.875"	!straal
	typePut[5000][1] = "5000"	!inhoud
	typePut[5000][2] = "-1.075"	!straal
	typePut[7000][1] = "7000"	!inhoud
	typePut[7000][2] = "-1.225"	!straal
	typePut[10000][1] = "10 000"	!inhoud
	typePut[10000][2] = "-1.500"		!straal
	typePut[15000][1] = "15 000"	!inhoud
	typePut[15000][2] = "-1.500"		!straal
	typePut[20000][1] = "20 000"	!inhoud
	typePut[15000][2] = "-1.725"		!straal
DEFINE STYLE "tekstVetMiddel" "Arial Narrow Bold", 2.5,1,0
DEFINE STYLE "tekstKlein" "Arial Narrow", 1.5,1,0
Volume = typePut[putVolume][1]
PARAGRAPH "putTekstPara" 2,
	0,
	0,
	0,
	1.15,
	0
	PEN 2
 	"Regenwaterput ("+ Volume +" liter)\n"
	STYLE "tekstKlein"
 	"volgens verordening hemelwater"
ENDPARAGRAPH
TEXTBLOCK "putTekst" 0,
	5, 	!anchor
	0,	!angle
	1,	!width_factor
	1,	!charspace_factor
	1,	!fixed_height 1=mm, 0=m
  "putTekstPara"
RICHTEXT2 0,0, "putTekst"
straal = typePut[putVolume][2]
fill putFill
poly2_b{5}       9,      3,      1,      3, putSolid, putEmpty,
                   0,            0,            1,            0,            0,            1,            0,
              straal, -4.440892098501E-16,     33,
        1.110223024625E-16, -5.551115123126E-16,    900,
                   0,          -90,   4033,
        1.110223024625E-16, -3.330669073875E-16,    900,
                   0,          -90,   4033,
        -2.22044604925E-16,            0,    900,
                   0,          -90,   4033,
        -1.110223024625E-16, -2.22044604925E-16,    900,
                   0,          -90,   4033
1 REPLY 1
remove
this scales the object when you change the width and height
The putvolume parameter needs to be a number greater than 1, as arrays start at 1 in GDL, a values list in parameter script or master script can solve this...
VALUES "parameter_name" [,]value_definition1 [, value_definition2, ...]
i.e. values "putVolume" 1500,2000,3000,5000,7000,10000,15000,20000
straal needs to be a number, not text (as you can't use text for the poly2_b{5} command)
define the numbers without Quotes
i.e.
typePut[2000][1] = 2000 !inhoud
typePut[2000][2] = -0.75 !straal
(no gaps in the numbers or it will error, 20 000 does not work)
STR (numeric_expression, length, fractions)
this will convert numbers to text for use in the paragraph (length is actually minimum length of text)
i.e. Volume = str(typePut[putVolume][1] ,1,0)
or if you want to keep your system formatting
STR (format_string, numeric_expression)
i.e.Volume = str("%#.0",typePut[putVolume][1])
get rid of the exponent numbers and change them to 0...to have the center of the circle an atoms width off center annoys me...
straal, 0, 33,
0, 0, 900,
0, -90, 4033,
0, 0, 900,
0, -90, 4033,
0, 0, 900,
0, -90, 4033,
0, 0, 900,
0, -90, 4033
if you still have errors...then try
when you make the parameters in the parameters list
putfill needs to be a Fill type
putSolid needs to be a Pen Type
putEmpty needs to be a Pen Type
putVolume needs to be a Real number or Interger type, as the actual number for length is based on meters and the displayed number may be mm or another unit. this would mean you have a much larger number i.e.1500000 for the smallest tank.
or just asign intergers
for putSolid pen 1 to 255
for putEmpty pen -1 to 255
for putfill 65(background or empty fill) or 64(solid or foreground fill)
i hope this helps
in parameter script
in 2d script
DIM typePut[][]
typePut[1500][1] = 1500 !inhoud
typePut[1500][2] = -0.75 !straal
typePut[3000][1] = 3000 !inhoud
typePut[3000][2] = -0.875 !straal
typePut[5000][1] = 5000 !inhoud
typePut[5000][2] = -1.075 !straal
typePut[7000][1] = 7000 !inhoud
typePut[7000][2] = -1.225 !straal
typePut[10000][1] = 10000 !inhoud
typePut[10000][2] = -1.500 !straal
typePut[15000][1] = 15000 !inhoud
typePut[15000][2] = -1.500 !straal
typePut[20000][1] = 20000 !inhoud
typePut[20000][2] = -1.725 !straal
0,
0,
0,
1.15,
0
PEN 2
STYLE "tekstKlein"
ENDPARAGRAPH
5, !anchor
0, !angle
1, !width_factor
"putTekstPara"
!!!!!!!!!!!!!!!!!!!!!!!Needs to be a number
fill putFill
straal, 0, 33,
0, 0, 900,
0, -90, 4033,
0, 0, 900,
0, -90, 4033,
0, 0, 900,
0, -90, 4033,
0, 0, 900,
0, -90, 4033
