Attributes Transfer
sedley
In AC26, when transferring attributes from walls and columns to others, the walls and columns height does not adjust.
This works fine in AC25.
Help Anyone.
Sedley Jeffers
St.Vincent & the Grenadines
Archicad 26 Full USA - Cadimage & Twinmotion
MacBook Pro M1 16", 64GB RAM. OSX Monterey
7 REPLIES 7
Check your Element Transfer Settings.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
That ( Element transfer settings ) can be exported from 25 to 26?
AC 27 INT 5003/WIN 11
I did everything I am capable of including that.
If you can direct me to exactly what I need to do, great.
I use the USA Mac version, the INT visions M1 version not having the same issue.
Sedley Jeffers
I believe the element transfer settings can be exported and imported but you may need to open the file in AC26 first, then export them and then open your new file and import them.
Lee Hankins
https://help.Graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F030_Inter...
Have a read of that.
Lee Hankins
Nice trick thanks @Lee Hankins .
Thanks everybody.
The the problem is unique to the file I'm working on.
Thanks.
Sedley Jeffers
