‎2021-09-27 03:59 PM - edited ‎2021-09-27 04:02 PM
Hi I'm struggling to design this simple but atypical window. do you have some recommendation how to reach this shape ?
Solved! Go to Solution.
‎2021-09-28 11:16 AM
The trick to get the hole to match the frame is to add a slab that is the overall shape of the window and give it an ID of WALLHOLE.
Then when you save it all as a window object, it will automatically create the correct shaped wall hole from that slab.
‎2021-09-28 11:21 AM
Jop You are right I din't get it that I have to be on windows settings.
But unfortunately there is non description how to reach this tape of window 😕
‎2021-09-28 11:36 AM
The first one with no image seems to be in English (2 & 3 are German I believe).
The 4th one, I got an error message when trying to download.
Just select and then press Download button.
It will be added to your Embedded Library.
As I said, I have not used this object but is is all stretchy in elevation and even a preview in plan by the looks.
There seem to be some description in the plan preview for what to do.
There will be a video by the creator @Hmooslechner somewhere in a post here.
I think this is the post with a link to a YouTube video.
‎2021-09-28 11:52 AM - last edited on ‎2021-10-03 01:22 AM by Laszlo Nagy
Thanks but for now I gave up this solution ... problems with libraries for (sweden version) and it's quite hard to get it how to do properly
‎2021-09-28 11:57 AM
Thanks, now I understand
‎2021-09-28 12:13 PM
Thanks a lot Barry. Just curios... are you answering this at 2:36 AM in your time zone ? 😅
‎2021-09-29 03:19 AM
No it was 5.36pm here.
In your profile settings there is an option to set the time zone.
My Settings > Preferences > General.
